02.25.2006, 02:53 PM
i wouldnt go for a 36120. if im not mistaken they have a 42000 rpm motor limit. the 3695 will do i think. also, i would go for the 2250 if funds permit. with the 51 tooth spur you will probably need a rather big pinion. so gearing shouldnt be a problem. mike can make you one if he can find the proper gear stock for it.
