Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.31.2010, 10:40 PM
I have completed a bit more progress today but no batterys for the camera ? DOH ! ! !
I tried quite a few different blades and found I was happiest with the blade labeled for "thick metal". No idea how many teeth per inch, but it wasn't very many. I found a slow RPM cut best and the larger tooth blades didn't clog like the finer teeth blades. The one that worked best was one of the more expensive blades Lowes had so I assume qaulity meant a big deal because some unlabeled ones I had wouldn't cut a warm turd. Bare in mind I was cutting 2 pieces at the same time so it was nearly 1/2" of material.
