09.01.2010, 11:51 AM
Got the Boca's 5x15x5 yesterday, went to Ace Hardware to pick up some 5mm washers and got them installed in both the 4x4s. I hope that this is a fix, especially for the one running the MMM/2650. As for the stock VXL, I think it will be a permanent fix. I am still pondering putting a larger 5x15mm washer in front of the bearing in the mount to keep dirt from getting in on that side, that is if I can find one.
Kind of a bummer that this truck takes everything I have dished out for it and that freaking bearing fails almost every time. Boca, better be the answer. Or I am going huge, flm probably.
