_dV
09.03.2010, 03:22 AM
Freeze: shock settings in the vid were
- 500 centistoke (50 wt) HPI oil
- stock piston
- single white spring (no short spring)
- tube but no other spacers
That was with the shock tower supports as well. They make a diff to how stiff settings feel.
Update: Went out for quick drive after work. Tried replacing the white springs with pink + the smallest spacer on top of the tube. Instantly much better, removed the small spacer, little better again. Less skatey on loose surface and less bouncey on bumps. Could still see that the dampening was too harsh. Will try 400 cst oil next time.
