InsaneRC
InsaneRC's Avatar
09.05.2010, 12:30 PM
Good cheap lipos? Where have you been for the last 2-3 years man?
www.hobbyking.com
You can get a 5s 5000mah 30-40c lipo for about $100 there. Occasionally you might get a weak or dead cell in a pack, but if you're only bashing then you could pickup 2 or 3 packs for the price of some 'branded' pack, and get the same or better performance..
The glitchbuster/ voltage protector cap doesnt give you extra power, it merely smooths out the power delivery and helps to prevent it bottoming out when the servo is really workign hard or the main pack voltage is sagging under acceleration- its an electrical buffer tank in essence. It wont neccesarily help in this instance because the input voltage is so low- if you have that motor geared for any kind of speed it will suck the life out of the lipo due to the high load and low overall power in the system ( power > watts = volts x amps- low voltage means high current draw, and that means higher temps and voltage droop )...
ok make sense.
does hobby king have any hard case lipos and mostly looking for 4s lipo since i will be racing it/bashing it. I can't really trust soft case lipos since i do some really hard bashing and have the lipo get damaged and watch my buggy go up in flames so yeah
Mat
Eletric is the New Nitro!!
Traxxas E-Revo
Marui Big Bear
Ofna Ultra LX-1E
