Thread: blown esc
wyattroa
09.05.2010, 08:50 PM
Originally Posted by scarletboa View Post
Differential Ratio: 4.5
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 20
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 1
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.3 : 1
Total Ratio: 10.35 : 1
Tire Circumference (inches): 23.56 inches (598.47 mm)
Rollout: 2.28:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 105.29 mph (169.13 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
there's your problem. the CC2200, or just about any motor for that matter, cannot handle that much gearing
usually, a good speed to gear for is 35-45mph. maybe 45-55mph with an oversized motor such as a castle/neu 1520 or a 1717
Just double check the pinion is 15 in there..But, this still doesnt make sense to me. The spur that everyone is running in their rc8t is the plastic 46 spur from the electric kit. Castle says to run the 2200kv for a truggy. If the engine got hot all of a sudden on 15 pinion then gearing the pinion down would have made the engine even hotter, am I correct in my thinking?
