I loved racing with
Panther Pythons on
Traxxas dish wheels with
Racers Edge two stage foam inserts. The Pythons were worn so I unglued them with acetone to reuse the dish wheels and the inserts. I bought some
Panther Plow boys thinking they had the same bead as the Pythons. They have a square bead that didn't fit the Traxxas dish wheels. I was disappointed so this is what I did to make them fit on the wheels. I just cut off the square bead.
I have 9 or 10 runs on these tires. They work pretty darn good. Good traction on a lot of surfaces and they don't seem to wear too fast.
If you do this, don't discard the square beads that were cut off, keep them they are good and thick elastics that you can use to hold the side of tires on the wheels to glue them.
Lastly, I cleaned my tires with water and dish soap before taping and gluing them. I tossed them in the dryer to dry them in a hurry. I found that Gorilla Tape sticks like crazy on hot tires with almost no wrinkles. When you tape your tires, heat them up first. Give it a try.
