Thread: blown esc
scarletboa
scarletboa's Avatar
09.06.2010, 06:24 PM
all you need to do is use a 10 or 11t pinion and you will be fine. it will also help you further if you got some 3s pack to run in series or some smaller packs to run in parallel because those monsters you are running must weigh a ton.
also, the reason i got such a high top speed was because i added 1" of tire ballooning. at lower speeds, they will not balloon as much.
Differential Ratio: 4.5
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 10
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 5.5
Tire Ballooning (inches): .4
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 4.6 : 1
Total Ratio: 20.7 : 1
Tire Circumference (inches): 19.79 inches (502.72 mm)
Rollout: 0.96:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 44.22 mph (71.03 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
a 10t pinion is what will make your truggy run happily.
