Thread: 1515 vs 1518
nuz69
nuz69's Avatar
09.09.2010, 09:20 PM
Originally Posted by phatmonk View Post
I have just swapped a CC 1515 2200kv for the 1518.How much longer is the 1518 rotor?My rotor on the 1518 will move in/out of the motor can 2-3mm.It always pushes back out though to line up the pinion to the spur.My 2200 also does this but very little.
On my Castle motors I can move the rotor a little too, I push the rotor and he comes back on the front end bell. I used blue loctite in order to definitely glue the front bearing in the end bell and I add a spacer at the rear of the rotor to optimize the rotor position / stator position.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
