kingdomracer
kingdomracer's Avatar
09.09.2010, 10:50 PM
I just came back from the track after testing the 7955TG and didn't experience the same hesitation at all. I did let my buddy drive and he got a glitch. I installed a CC BEC and took out the 7950TG and there was according to him still a slight glitch. Well, after talking a bit I believe my glitch is still ESC related and have a hunch that it's my fault after all. You see at my track some of the other guys who run electric use reverse (as to not have to wait for the turn marshall if your up against a wall or pipe) and I followed suit a couple of races back. I believe my ESC is simply stalling due to the reverse setting. Too bad it got real late because I definitely wanted to test it out. But, anyways the reason I'm sharing this is to hopefully get some feedback as to the possibility of the reverse setting being the culprit. And for those of you experiencing this glitch; Do you have the reverse setting on?
JESUS says "Fix it B4 it Breaks"
