What???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
What??? - 09.12.2010, 08:48 AM
Originally Posted by medusa'd maxx View Post
I knew I'd have to make some mods just used to flm parts made for each other actually fitting, got an email from FLM saying "slight modifications" to make them fit would not void my warranty.
I'm using (fingers crossed) an integy evo 4 upper A arm with a RPM true trac lower arm - I've drilled the rpm arm outboard of the regular shock mounts and the shock fits nicely
By the way this maxx is going to be 80 cm long and its running a castle neu 1717 with lots of cells
I'll post some pics soon
80CM LONGER? Thats like 40" longer, which would make your truck about 58" long. Are you sure that you did not mean 80mm longer?
Anyway it sounds like you are going to an aweful lot of trouble just to use these shocks. It would have been easier to use the UE SuperMaxx shock, and they are in stock. Not that I am aposed to making mods. I love seeing a good mod done to trucks if it is done right, and looks good in the end. Although your combination of RPM and Integy sounds a little bit strange to me. Just saying.
SUPERMAXX YOUR LIFE.
