thzero
09.15.2010, 07:14 PM
As reference I am running a 2200kv with MMM on 5S on a 16.4lb 5T conversion and I'm not seeing this. So it is probably not the XL chassis and its not the tires. Maybe it "sealing" the front end might be part of it but maybe not.
But yeah get a heat gun/temp guage.
Are the tires different size from stock that you need to adjust gearing? What about timing in the ESC? Low/Medium/High? I had some heat issues with my RC8Te and dropped down to the Low settings and that helped.
