09.17.2010, 10:25 AM
On the EVX2, you'll need a 2s Smartstop, #5470. You would then hook it up on the battery lead which feeds the BEC circuit since this will always drain the batteries slightly more than the other side.
To find which side is which, plug a battery into 1 side of the EVX and try to turn it on. If it turns on, then you have the BEC side. If not unplug and try the other battery connection. This one should be the BEC in this case.
