pinkpanda3310
pinkpanda3310's Avatar
09.22.2010, 12:17 PM
My current 35c hyperion lipos are extremely powerful.. .they outperform any 35c lipo i have tested from hobbyking so far, including some expensive lipos i bought here in the UK from a reputable seller which cost me just as much as my hyperions (problem is, hyperion lipos are crap in terms of their soldering!!!)
So your hyperions out perform anything you have even with dodgy solder.....
yes they definitely will!!! (i actually believe they would be too much in terms of punch causing everything to fall apart haha...
....and you would rather rip apart your car with higher voltage than higher c rating? I understand you why you are worried about heat issues with higher c and dodgy solder but it sounds like you have little faith in hyperion when the quick and easy fix would be...
Originally Posted by reno911 View Post
i would just get the iron out and heat them all together.
I don't know what charger you use but if money is tight then you don't want to be getting batteries and charger to suit.
