crazyjr
crazyjr's Avatar
09.22.2010, 06:00 PM
The new Sidewinder SCT version handles similar power to the MMP, but is a lot less expensive (but doesn't have the features! -- it's a linear BEC, so limited to 3S, and has no sensor port...)
The motors will be available separately from controllers.
I don't really know what you mean by 550 or 540 based -- Mabuchi motor sizes?
The 1410 is the longest at 52.90mm (to be within the ROAR mandated 53.00mm length maximum.)
The 1406 motors are somewhat shorter.
And available Kvs are:
1410: 3800Kv
1406: 4600, 5200, 6700, 7700 -- more added soon.
Thanx!
Patrick
Yes i was meaning like standard 540 and 550 brushed. I DL'ed the Roar rule book and saw that they only allow 12.51mm dia, 25mm long, 2 pole rotors. Does this mean a 2 pole motor with Neu type windings? also I'd like to see either the 1410 or the 1406 in a 3000kv or lower range (preferably around 2500kv) will that be possible?
