Pdelcast
Pdelcast's Avatar
09.22.2010, 08:36 PM
Originally Posted by crazyjr View Post
So you could run a 1506 with a 1/8 shaft in a stadium truck for example, that would be too much, but fun to try.
thanks for the explanation Patrick, Two last question, Will these motors replace the current standard castle 1/10 motors currently in use? and, Are you planning a 4 pole replacement for the mini classes?
thanks and sorry for all the questions, I prefer the smaller 1/10 classes over MT and truggy.
EDIT: Holy crap, I just found out lehner xl and 1920 W/3.17mmshaft motors are allowed by patricks words. I wonder if smaller diameter motors would be allowed if not longer than max length?
No, you couldn't run those motors, because they have a diameter over 36mm...
A mabuchi 540 size motor is 36mm diameter and 55mm length... and that's defined as the MAXIMUM allowable dimension for ROAR modified.
Lehner XL is longer than 53mm too...
Those are motor sizes, not rotor sizes.
Patrick del Castillo
President, Principle Engineer
