09.23.2010, 09:25 AM
Wait till you see the Blue Lipo, the leads weren't properly wet before heating to the board. Allowing the wires to fray and peal away from the joint on impacts. I hope the 5000mah that has been doing so well with me has better connections. Though the 5000mah has a front center exit and those setups usually have more wire inside the case, so less tug and pull compared to a side exit.
