09.25.2010, 05:03 PM
Ubuntu is pretty much the way to go for desktop linux at this point, in my opinion.
If windows 7 is installed first, you won't have an issue with dual booting. You can shrink the windows partition easily enough, ubuntu should walk you through it in the install, I think. (Been a while since I dual booted).
The only issue you typically run into normally is audio / sound cards.
It all works fine, you won't have huge problems with most modern hardware.
Have fun!
Tony
