MetalMan
MetalMan's Avatar
02.26.2006, 11:34 PM
Originally Posted by Superemaxx89
What does that mean?
That means that through a cable the two can communicate with each other. For example, if a pack is severely out of balance, the balancer can tell the charger to slow the charge rate down. It also enables you to see the individual cell voltages (as provided by the balancer) on the charger's display screen.
Originally Posted by squeeforever
metalman- i plan on using a mrc 989 to charge 2 3s packs. will this allow me to charge and balance these all at once? or will i still need 2 balancers?
It could work, but would give the balancer a heck of a time trying to balance 2 packs that weren't started charging at the same time. It would be best to use 2 individual balancers for a setup like this.
