BIG-block
09.26.2010, 12:54 PM
Since the thread is up and going again I thought that I would mention that I also run Turnigy and Zippy lipos. I also used to have some Rhino batts when I had my heli but have since sold them.
Anyway they perform better than their price would indicate. No real issues other then the last Turnigy 5000 40C packs I bought. In one of the 3S packs one of the cells lagged behind on the initial charge and it was taking my charger ages to bring it up. Being impatient I made an adapter and just charged that one cell @ 1A till it came up to 4.2V. Since I have put about 20 cycles on that particular pack and cells have always stayed within .01-.02 volts of each other. I don't know whay the initial charge was being so difficult but it hasn't happened since and that was the only Turnigy/Zippy batt that did that on me.
What does piss me off about these batteries is their discharge wires. 8awg wire is just overkill IMO. If I needed them then my ESC would have came with them too. Also the way the wires come out form the pack on the side is a bit of a pain for my application (Revo). What I did is stripped the packs and removed the 8awg wires. I replaced them with 10awg wires and also bent the end of the wire at a 90 degree angle so the wires will come out from the top. Fits much better into my Revo now. Also I replaced the pissy heat shrink they come with with much thicker heat shrink. They are half way to hard case now. LOL.
Anyway for me they do the job just fine. My truck can do standing backflips on Zippy 4S 5800 30C set up and is just stupid fast on Turnigy 6S 5000 40C setup. Batts are cool. Pretty much ambient temp unless I do continuous speed runs or drive through grass and even then they just get warm. My MMM stays pretty cool too (as do my other ESCs: HW and Quark). When I am bashing in the yard the fan hardly comes on (I wired a little LED so I can see when the fan is running). About the only thing that gets warm is my motor and even that is within Castles recommendations.
I think that Zippy/Turnigy are great cells but their assembly could be better. For someone who knows what they are doing with their batts and exactly what they are asking from them you should be just fine. I will keep using them.
