MetalMan
MetalMan's Avatar
02.27.2006, 09:22 AM
Oh... I thought you meant you would charge 2 3s packs on separate channels. Well, in that case it would work. BUT, the taps from the two packs have to be merged so that whichever cells between the two packs that are put in series share the same tap wire. I'm not exactly sure how the TP balancer works, but if it does have two separate tap ports then you wouldn't need to join the wires.
