andreazinno
09.28.2010, 07:18 AM
Originally Posted by Bmr4life View Post
Yeah. I need to order some 6S batteries. How many amps do I need? Is 100 enough?
The problem with 6s batteries is the space to fit them in the FLM chassis.
In my FLM forward chassis Savage, using a Castle 1520 (its diameter is about 9mm lower than the 1717) with a spur of 52 and pinion of 25 (so the motor is as far as it possibile from the left chassis plates), I have about 46mm width to mount batteries, just enough to mount 6s Lipo of 4.000 / 4.500 Mah.
If You have no more than 42,5 mm (with the spacers), I guess you will be in trouble to find 6s pack of that width (maybe something can be found, but with no more than 3.000 Mah).
Bye, Andrea.
