09.28.2010, 01:12 PM
Man, this thread just will not die...
The soldering on that pack looks like the stuff I did before I got a decent iron....
If you are not getting any reading thru the wires go directly to the cells where the wires are soldered. Isolate each cell by putting the pos probe on the pos end and the neg on the neg and check each cell. The switch your multimeter to ohms and check the continuity of the balancer wires. I have had a few balancer wires go bad...
If you may have a loose tab on one of the cells. At that point you can toss the pack of have it reconfigured to remove the bad cell (my choice).
Hope this helps.
34 pages, wow. My rc legacy.
