hemiblas
hemiblas's Avatar
09.29.2010, 12:59 AM
I think you might be risking more by running them individually if the venom packs arent up to the task of providing the current needed for the speed controller in a heavy MT. I would run them in parallel asap. Make sure you check the wiring diagrams and get the parallel connection right, since running them in series could make for a lot of smoke. Maybe measure the voltage before you connect them up to the ESC before you make your first run to make sure you have 14.8V.
