Sneeck
RC-Monster Custom
Sneeck's Avatar
02.27.2006, 02:04 PM
The Wanderer / Feigao motor's are just like Hacker's, only with a pressed endbell and lower quality winding's.(meaning the hacker's are better, but also more then double the Wanderer's price tag.)
The wanderer 9xl has a 5 mm shaft and should be used with an ofna spur and strobe slipper. 18/51 is way to high. You should drop 1 tooth for every cell you add I once read here, but other people are better at gear ratio's than me.
If you got money to spend, get a Lehner 1950.
  Send a message via MSN to Sneeck
