"Frostbyte II" still running warm
Freezebyte
"Frostbyte II" still running warm - 10.01.2010, 06:21 PM
Allright, just got back in from around a 10-12 minute run with FB2 just outside the apt complex. I was driving it with a new RCM 18t pinion with standard 44t spur gear.
I ran in standard 2-3 inch recently mowed grass with a bunch of high speed runs, stops slide turns in and out of the grass and small sandpit whee the playground equipment was at. I stopped and checked temps several times and on my motor were showing around 120F at the hottest point according to my Duratrax flashpoint gun and the MMM fan was always running when brought the truck in.
I then moved onto flat, rocky dirt area that had random spots of fine dirt, small rocks laid out and random slippery grass/weed spots. I did a variety of high speed runs, slide turns, dead stop full throttle mashes, wheelies and just gave the truck a good hard run for around a minute or two and brought it back in a few times for temp measurements. The motor was now showing 154 F in the hottest area and I was showing around 120-130 F on the side of the ESC next to the motor with the fan always blowing.
I drove the truck back slowly on the concrete and disconnected my Turnigy 5200mah 30c 2s lipos and found the packs to be fairly warm. Not hot but definentely warm, warmest i've ever felt on them. It was sunny outside and around the 60's
So, even with the 20t to 18t pinion reduction, it looks like this XL conversion is still putting alot of load on the entire brushless system. I'm wondering if I need to step up to 6S power so it can move the heavier mass from the tires on a larger footprint from the XL conversion easier Or is it something else? My punch was at 0% with 0% brake drag, 30% brakes and 25% reverse throttle with LVC at 3.5v and timing set to normal. Keep in mind also that the motor endbell is still sealed with button bolts to keep dirt out of the motor, if that makes any difference
Input or suggestions?
