Brushless J-truggy
Jasper
Brushless J-truggy - 02.27.2006, 06:07 PM
Hello people,
I need some advice about the wanderer XL motors. I am designing a chassis in autocad, with as base point two f/r diff from an 1/8 buggy and a center diff (46 tooth plastic spur) and the savage servo steering setup. I also use the savage front and rear suspension. So I can use my 23mm wabash wheels with 40 serie bowties. For the shocks I use the UE racerx. The truck will be 482mm long and 190mm wide. In the chassis I made 10 holes at each side for the cells. The chassis will be 4mm thick, the upperdeck 3mm and the left motormount en the right mount 8mm.
I want to use 18/20 cells. The xushobby ubec will replace my heavy receiverpack. I still use the 9920. I have a 12,14,15,16,18 and 20 tooth mod1, 5mm bore pinion laying around.
For my savage I have a 7XL. But that is too hot for my setup and the centerdiff with only 46 tooth. I used the calculator to get to know what motor is the best. And the wanderer 13XL came out to be the best choice.
Do you agree with that?
If anyone has other comments, please share!
