kingdomracer
kingdomracer's Avatar
10.05.2010, 06:52 PM
Well an update on my last thoughts...NO...glitch still there!
But, I do feel I came up with a real solution.
First I'm going to use the MMP internal BEC to power my receiver and transponder, in other words plug it directly into the radio with all wires still in the plug including the red wire.
Second, I'm going to use the CC BEC to power just the HiTec 7945TG (just got it), so basically connect both the CC BEC and servo wire into a heavy duty servo Y adapter and before plugging it into the radio disconnect the red wire since the servo is what needs to be powered with a signal wire but the CC BEC just needs to be grounded back to the ESC.
I don't know if anyone has suggested this fix or tried it but theoretically it is sound and should work. I'll post up my results.
JESUS says "Fix it B4 it Breaks"
