Originally Posted by MindThoughts
Thank you snellemin-
I just got off the phone with Howard at FMA Direct where I originally ordered and purchased two powerlab 8, Combo Number Two Balance Chargers. Howard help me step by step, upload the latest Firmware via my laptop windows 7 computer via internett- and it only took a few minutes and now the charger can charge at the full 40amps. This higher amperage charging has been in bata testing now for many months, Howard explain to me that this information was top secret because they knew once they came out with a 30amp charger, everyone would follow suit and that's exactly what happen. It was further explain to me that all these companies which are now sudenly offering high powered 30 amp chargers- or at least many of them- have not done proper beta testing which is why the chargers are blowing up on people, whereas not one such malfunction with any of the well tested PowerLab 8 chargers. Nate, short for Nathan- is one of the main electrical engineers that has made this new firmware possible. My PowerLab 8 now reads- Version 3.2 when I turn it on. And I now have access to charge lipos at rates up to 40 amps. I would have like the Maximum Charge Amperage to be at least 80 or so amps, but I'm certainly happy and very grateful for the extra ten amps now possible. After all, my old TC-1030 chargers maxed out at ten amps each. The fact that A CellPro PowerLab 8 metaphorical tune up has given us an extra unexpected ten amps to charge with is sure a truly great suprise indeed. Great Work FMA Direct- keep up this great work- Your company is certainly a true leader in the RC industry. And I must say, I've only had to bring one of my two powerlab 8 chargers with me to the track, and may sell my second charger because I have no need for two of these chargers going at once. After all, as soon as I come back to the pit after runnig my buggy back to back battery packs charge after charge all day- my batteries are always fully charged well before I even finish my marathon daily practice runs. I've never been so happy with a charger. But now i'm actually suprised that my brand new Thunder Power 50c 5200mah 3cell lipos can only take a 32amp max charge rate. I will need to find a new set of lipos which will fully utilize the full 40amps of charging ability. As for a power supply- I'm using a just over three pound- common sense RC 43amps 12volts Power Supply which only cost just over 100.oo dollars. This is a great day indeed. By the way- my lipos continue to charge in less than ten minutes at 30amps, and not even get warm doing so. Although I do use a lipo safe charging bag as a precaution. Have a great day ;)
pm me if you want to sell it
