made one cut and a little drawing. i think this could be a good shape for the vertical plate.
there will be a "table" so to speak about half way up where you can see the dotted lines on the drawing. this will be where the ESC will go, it wil also make the CF side much stronger.
http://www.amainhobbies.com/product_...ssis-Joint-Set
those things will be used to mount the table and also to mount the vertical paltes to the chassis. i'll buy a couple sets of them.
