Finnster
KillaHurtz
Finnster's Avatar
10.07.2010, 06:12 PM
nothing some axle extenders couldnt fix :)
Looks like a great size... could you measure the wheel base from axle to axle please...
It loos a very similar size to the DB-17 conversion maybe a tiny bit longer?
Yeah, I looked at the integy axle adapters, and you could always stack those with the XL ext axles, but then its a huge ways off the bearing and just asking for trouble in a crash imo. FLM ext arms + integy adapters would get you there, but I don't want to drop that much for alu arms that bend. PLus this thing will be a tank as it is.
What I am hoping for is that the mbx6t arms work well, then I can use other offset truggy hexes to get me out farther. Least it starts on a good foundation.
BTW, its ~510mm axle to axle. Almost extactly what an FG truck is
