ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
10.07.2010, 11:10 PM
Check your Rear diff... Sounds like the pinion is slipping on the ring gear to me....
Listening again, I'd also check that the output shaft of the motor isnt slipping on the Grub Screw of the Center driveshaft.
You said it does it when you hammer it?
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
