kingdomracer
kingdomracer's Avatar
10.09.2010, 03:38 PM
Originally Posted by hlb14 View Post
if i went with the 4.5 (5000kv) subrtact 20% for the tuning rotor and a few hundred when you add a load and that would put me close to the 3700 that i based my calculations on...
Just wanted to know an update on this setup. I'm debating on ordering the same setup or go with the 5.5
I'm trying to keep temps down in a Slash 4x4.
I like the idea of running the 550 motor with low timing and high sensored cheat mode timing for the straights and kick in around 8,000-12,000 (depending on actual testing to narrow it down).
I already own the 6.5 and 14mm tuning rotor. I like this setup on smaller tracks but I need a setup for larger/open tracks.
JESUS says "Fix it B4 it Breaks"
