Be sure to use 10 Gauge(55 Continuous Amp- Max ) Wire- Charge Leads On Your PL8.
MindThoughts
Be sure to use 10 Gauge(55 Continuous Amp- Max ) Wire- Charge Leads On Your PL8. - 10.09.2010, 07:45 PM
That's truly and completely awesome snellemin.
As a side note, for anyone just now buying your PowerLab 8 Balance Charger, it's important to upgrade to the Version Two Charge Leads, which are 10 Guage 55 Amp Max Continuous Power. The original Version 1 charge wire leads were meant for 30 Amp charging. With the new Firmware Update, it's important to also update our charge leads(which are the wires that connect the charger to the battery). FMA Direct is in the process of offering their own version two 10 Gauge Charge Leads to be used with the new Firmware Update, Or, we can make our own from 10 Guage wire, with 4mm Bullet conectors at one end, and a male deans plug at the other end(plugs into our battery). Have a great day ;)
It's nice to charge the Acepow 5000mah @ 40A in less than 9 minutes. I 4584mah went back in. Man do I love this charger.
Hyper 9E And Losi 8ight-E. Each model with Full Matrix Concepts Inc Carbon Fiber Chassis & Kit. Xcelorin 2100kv + Xcelorin ESC & 1409 1Y Neu/Castle + MMM. 1344watt 40amp PowerLab 8.
