10.10.2010, 10:36 AM
Originally Posted by Klausen View Post
Great, I have 2 zippies on 40c. 2s though, but should be ok to start out with. Then I can allways get some 3s lipos later.
Seeing as you are over seas, the Zippies don't take 3-4 weeks to arrive like they do here in the US...go with them. The 1520 would be a beast on 6s if you decide to go that route.
Also, when running two batts together you don't need quite as high a C rating as if you were running a single batt set up. Nothing wrong with running a high C rated batt in a 2 batt set up though
