Manne
10.11.2010, 07:13 AM
Check your solderings and connectors, a connector that is old and worn will work like a resistor. Maybe you are undergeared? My Erbe were running hot when it was geared for 40, geared up to 45 and problem solved... These 4pole motors donīt like to rev high they like to work with the torque. I hope you will solve the problem.
