nuz69
nuz69's Avatar
10.11.2010, 08:46 AM
+1 on hyperion, 5000mAh 25C G3 is well enough for a 4S buggy ;) You said earlier that you have done the test with 2 different ESC + motor combos with same problem ? You should definitly check the batteries or the motor mount.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
