redshift
RC-Monster Square Tube
redshift's Avatar
10.11.2010, 06:23 PM
"Red you are right in line with what I was thinking. I was going to make 2 of the extensions in carbon fiber to sandwhich the top peice made out of aluminum, to center the shock"
Well, sort of. I was envisioning the dogleg exts. being offset either F or R, and tieing them together below the upper A arm. The body post mount could then be offset the opposite side to retain your post centerline. With the oversized wheels I really think you need the extra control of two shocks.
Your idea would certainly score big points for uniqueness, but I lean toward that being MTTIW honestly. And you don't necessarily have to run 8 springs either as I'm sure you're aware. We'll just have to see where it goes!
