ANGRY-ALIEN
ANGRY-ALIEN's Avatar
10.12.2010, 11:36 AM
Originally Posted by RC toy View Post
I dont understand how did you mount Pro-line steering/servo saver? I know that with UE steering/servo saver you have to mount it to flat surface(I mean you have to cut those two litle poles from stock emaxx 3905 chassis). So does this one you are using mounts the same as UE or you have done modifications?
PS. : What runtimes you get with your 5S batteries?(also tell me the mah count)
The pro-line steering servo saver assembly or the truck didn't need any modifications to install it... it's pretty straight forward actually... well.... both the carbon upper
plate and skid plate that it is mounted between are flat... I can't recall ever reading that modifications to the chassis are required for this servo saver...
I bash a lot (full throttle mostly)... the truck will run up to 20 mins before the lvc kicks in... not bad for 'cheap' packs... they are 40C and 4000mah... I'm going get some
40c 5000s when i eventually start racing...
Alien
