10.12.2010, 09:25 PM
15-20 minutes of run time per battery is very good considering the weight of the truggy. If you tweak your esc settings a bit you main gain another minute or two. I set my punch control down to 70% and that does make a difference. As far as hop ups go..I have Kings Head rear arm holders and that's basically it. It is a prospect version so there really wasn't muck to do on it......and yes it is a bit loud at high speeds with the metal on metal gears
