check it out guys,
cut some CF tonight, with the hacksaw blade. yeah, thats right, just holding a blade, no handle attached.
i used a piece aluminum stock as a straight edge clamped along each edge cut. i had each side bolted together so that each side would at least share the same mistakes :)
had to take it apart before the last few cuts for some test fitting.
what do you think?
