Finnster
KillaHurtz
Finnster's Avatar
10.13.2010, 10:43 AM
You ok _dv?
yea i was contemplating the hellfire ones...
But i when i saw these i thought they were awesome! They are from a hyper st rear turn buckles
http://cgi.ebay.co.uk/Hobao-Hyper-ST...item255b4068ac
I like the bend in the rod as i have grinded a little too much on my RSC Conversion and its when at full throw... the steering isnt tight, but loose... so hopefully this small bend in the rod end will solve my minor issue and pull my steering inwards a little bit... terrible explanation but ill get pics...
Kyosho makes some bent rod ends as well (for the 777 IIRC)
They are for str rods, so they are not as large as the HST rodends as well. May or may not be what you want, and depends on the clearance of your wheels
EDIT: Here they are. they are actually a good mod for the knuckle end of the HST to give the knuckle a bit more clearance and better throw.
