True that jayjay
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
True that jayjay - 10.19.2010, 07:47 AM
True that JayJay. That thing seems to have a ton of power to put to the wheels if you can just use it in the right place under the right circumstances. You should try that truck on some tarmac and see how fast you can get it up to. I bet you would easily run up in the 70mph range and even higher if your vehicle was setup right for making those kind of runs.
SUPERMAXX YOUR LIFE.
