10.20.2010, 12:40 AM
you're really close to the 15 minute mark already, so the extra 200mah might be enough.
You could also try a pinion with 1 or 2 less teeth. The lighter load might just give you the increase in runtime that you need. But of couirse check temperature often when changing gearing.
Good luck!!
