10.20.2010, 03:24 PM
Wasn't tryin to ruffle your feathers bashem. Just wanted to point out that you do not need an external bec to run the mmpro as your statement implied. As my previous posts indicated it would seem you do indeed have knowledge pertaining to the hobby and did eveything in your power to get the mmpro to work in your setup. My brain to mouth filter is pretty much non existant so you will have to forgive me for being so blunt. The only real solution is to run what works for your setup be it novak or whatever. Who knows we may come to find it was just your specific mmpro unit in the end. Whatever the case may be many people have had great luck while others have not. I have seen the posts as well on other forums and dealt with people personally at the track with the same issue. The people that came to me at the track let me work it out and I got all but one system working normally. All setups being slightly different I reall can't say what causes it exactly, but from my experience lightening the load on the bec has worked.
