slimthelineman
slimthelineman's Avatar
10.21.2010, 05:31 PM
Gotta do em in series and remove the ground from one iirc. Talked about it in the thread on them. But be carefull there will be a shock hazard present as there would be a difference in voltage between the two cases unless you could find some really expensive material to cover them with....
