josh9mille
josh9mille's Avatar
10.22.2010, 01:19 AM
And just a little tip. Some lucas/stp oil stabilizer in your flux steel geared tranny will make it last alot longer. A teaspoon or so will do, just enough to cover the teeth of the bottom gear so when it spins it picks the oil up.
I might have to try this. Maybe use some RTV sealant on the tranny halves so it doesnt leak. I play with those Lucas oil dispays every time i go to the parts house, it seems to work pretty well.
