LiqrSicc
LiqrSicc's Avatar
10.23.2010, 01:11 PM
Originally Posted by _dV View Post
mmm shiny, much nicer than the purple.
How thick are the carbon fibre TVPs? Must be around twice as thick as stock looking at the weight. I expected them to be lighter.
In my instructions for the kit it says to remove a bit of that part anyway (which is part of the shock tower).
Apparently the bolts in the c hub come loose a bit. You could fix via this method. Image courtesy Jahay
The CF TVP is about 4mm thick. It's pretty thick stuff. But for an extra 2" length, 15 grams isn't much.
You're right, it's the shock mount. I didn't have instructions to the RSC so it took me a little longer to figure it out.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
