SpeedAssault
SpeedAssault's Avatar
10.25.2010, 10:49 PM
Updates
Needing new shafts . ( keep breaking)
Installed my custom adjustable brake button on the DX6i (silver tab on the grip behind the throttle)
NEW Tires !
Reinforced the chassis
New upper chassis rails
New Aluminum motor plate
Moved the Motor and battery to left side for better weight distrubution
Results were great !
I was able to drive it with the huge body on it and reach 58mph before it STARTED to FLY up into the AIR !
what happen I think is the rear stub axle broke which could have aided in the front lifting. Happened so fast the front was an easy 10 inches off the ground before I released the throttle
Just before new mods were done
Added a 2 way momentary button with a switch so I can select if I want momentary on or off.
After Mod, the new momentary for mixing activated by my thumb located below steering behind black 3 way switch behind the trigger
