Originally posted by RC-Monster Mike
You should be alright using the controllers BEC with a single servo. The UBEC will provide slightly higher voltage, but the controller's bec should hold up just fine with a single servo.
Thank you Mike for your professinal attitude...once you make a sale it doesn't end for you, which will make me spend more money.
Does higher voltage provide more power? What would you do?
Also, which aluminum wheel you have that is lighter and will work with 40 seris road tires?
Thanks
